Hi my friends!
Is possible to change the Feature Class Tolerance?
If so, how can I do it?
I want to set 0,01001 m instead of 0,0285714... as below.
ArcGIS 9.3Licence Type ArcInfo
Thanks for support!
Once a feature class is created, you will not be allowed to change its tolerance/resolution.
What you could do is create a new feature class with desired resolution and tolerance, and import the attribute schema from the old feature class.
Once the feature class is created, then you could just use Append tool to transfer all the records from old feature class to new feature class.
What is the version of ArcGIS Desktop?
