One of my field crews has had an issue with a about 10 of his surveys failing to submit when he attempted to do so from the field. The surveys appeared to submit correctly (they disappear from his outbox) but they were missing from the hosted feature layer and related map so it is clear they did not. When we tried to edit and resubmit through the sent box we get the "Update error code 1019 - The specified feature could not be updated or does not exist." It would seem everything was filled out correctly and our survey does NOT use repeats. Has anyone else had any issue with this and if so is this a known bug? Also, the surveys are now stuck in his outbox. I've attached a log file from his device.
Josh
Hi James Tedrick,
Does this mean that we cannot save, edit and then submit Surveys in the Survey123 app? I have a user who is unable to submit a days worth of field work and is getting this exact error. She tried to modify Surveys and submit them once she returned to the office and now we are stuck with surveys that won't submit. Any suggestions or workarounds?
Jacqueline
Hi Josh,
That's interesting - the log you provided shows that the surveys were updating an existing feature (which would explain the error being displayed).
They were not. They would have been created as a new survey.
Can you provide a bit more detail on the workflow? Were the forms loaded from an Inbox?
