Survey 123 may be a good option for my project. My next question is, can I edit the data after I use the pulldata () function? From what I can tell, the imported data is not editable. Please advise.
Hi Sage,
Yes, you can modify the value returned via a pulldata() calculation that is in the text field.
Phil.
Can you please tell me how I can edit the value in the text field (type: note) that the calculation returns?
You can only modify the pulldata() calculation in Connect, not once it is published, but you can edit the value in the text field that the calculation returns.
Good new! Thanks. I'm new to Survey123. Anyway you can be more specific on how I modify the calculation. Currently, it is simply printing the calculated text result - ${adCalc2}.
