I just found from the crew that if you are offline you cannot type in custom lat/longs into the little map.
Why? How can my crew use the type in feature offline then? Would a tpk help?
Hi Doug,
Currently you cannot enter the manual entry mode of the map when offline and there is not a TPK. Have a TPK (even if only a few levels) will enable entry.
Yea but I do not want to geocode i just want to type in a decimal degrees lat/long. I should be able to at enter that as text.
I believe the search function is referencing the ESRI geocoding services so you'd have to be online. I believe you can add your own geocoding service. Maybe something to google and see what others have done.
