I have a Survey question that is simply the temperature. Our field guys won't be working on days that are -200 degrees or 200 degrees, but I can't figure out how to force there answers to the question between a certain range. How do you do this?
In the constraints field try the following: .>-20 and .<120
Yep, I thought I had tried that as well.
I have Gremlins...
The work our guys do usually can't be done when the ground is frozen, so -20 may be giving them a lot of leeway.
-20 to 120 goodness I wish. We have a range of -40 to 110. But for safety concerns we don't send out crews when it is that cold.
Easy for you to say. hehe
I am not familiar with setting up a domain.
I can't get the constraint's syntax correct for a range of -20 to 120.
If you are using Survey123 Connect you could set up a Constraint that would limit the values to be entered.
Set up a domain for the question that has a ranged value. You can set the minimum and the maximum.
