I just installed AFA 400 (previously used 370). I am trying to sign into my Portal Site (10.6.1). I am using AutoCAD 2019. The Sign in page recognizes my Portal and I can see all of my public services. But when I click Sign In in the upper right corner of the page I get "Invalid client_id Error: 400." I would like to try and fix this issue, but I do not know where to start. Any suggestions on how to diagnose the issue would be much appreciated. Thank you
Josh
Hi Josh,
The reason you are getting this error is because Portal versions before 10.7.1 do not have ArcGIS for AutoCAD registered automatically as an application. The solution is just a matter of letting your portal know that ArcGIS for AutoCAD is a trusted application.
Follow the following steps (you will need to be a portal administrator):
To add ArcGIS for AutoCAD as an application to your portal, complete the following steps:
To get the app ID, complete the following steps:
To change the app ID, complete the following steps:
ArcGIS for AutoCAD is now registered with your portal.
- Randy
Hello Randy,
That worked. Thank you for the info.
