I am using an ESRI Combo Box in my toolbar. This Combo Box is loaded with the IDs of whatever polygons are in my map. When a user switches to another location, with a whole new set of polygons, I want my Combo Box to update itself. The problem is that I can't seem to figure out how to run my Update/Populate logic from outside of the combobox code. I need to be able to tell the combo box from other functions to revalidate or reinitialize itself? I think I need to make some static reference to this function, but can't seem to be able to accomplish this? The below code works initially, but when the user switches, i need to be able to call updateCombo from anywhere, or just tell the combo to reload.
<SPAN class="keyword token">public</SPAN> <SPAN class="token function">GoToCurrent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">UpdateCombo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">async</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">UpdateCombo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">try</SPAN>
Enabled <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">Clear</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
SortedSet<SPAN class="operator token"><</SPAN><SPAN class="keyword token">string</SPAN><SPAN class="operator token">></SPAN> FieldIdList <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> FeatureServiceManagement<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getFeatureLayerUniqueList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Current Field"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"CurrentFieldId"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>FieldIdList<SPAN class="punctuation token">.</SPAN><SPAN class="token function">IsNullOrEmpty</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">foreach</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">string</SPAN> fieldID <SPAN class="keyword token">in</SPAN> FieldIdList<SPAN class="punctuation token">)</SPAN>
<SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ComboBoxItem</SPAN><SPAN class="punctuation token">(</SPAN>fieldID<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
Enabled <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">Exception</SPAN> e<SPAN class="punctuation token">)</SPAN>
<SPAN class="token function">logError</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"UpdateCombo"</SPAN><SPAN class="punctuation token">,</SPAN> e<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
