I'd like to update my stand alone sql table base on values returned from my selection set. I was able to get the selection part but I couldn't find any snippets for updating sql table. Thank you for your help. Your help is greatly appreciated.
Hi Rich,
I'm a little confused here so let's clarify more about my table.
Yes I can have my table live inside a geodatabase but my table is just a tabular table.
In ArcObjects for Arcmap addin, I used these codes to update a sql table doesn't matter where my table is. So you say in ProSDK I can no longer do that? Thanks Rich!
Dim sqlConnection As New SqlConnection(sConStr)
Dim cmdUpdate As New SqlCommand
cmdUpdate.Connection = sqlConnection
cmdUpdate.CommandType = CommandType.StoredProcedure
cmdUpdate.CommandText = "sp_CalculateRate"
cmdUpdate.Parameters.Add(New SqlParameter With {.ParameterName = "@ABCD", .SqlDbType = SqlDbType.VarChar, .Value = strABCD})
cmdUpdate.Parameters.Add(New SqlParameter With {.ParameterName = "@EFGH", .SqlDbType = SqlDbType.VarChar, .Value = strEFGH})
sqlConnection.Open()
cmdUpdate.ExecuteNonQuery()
cmdUpdate.Dispose()
sqlConnection.Close()
The Pro SDK doesn't allow you to edit non-geodatabase tables. You could either add that SQL table to a geodatabase, or edit it using non-ArcGIS routines.
The easiest solution would be to register the table with a geodatabase? Is there a reason you cannot do this?
--Rich
p.s. Technically, you can also edit a non-geodatabasea table if it is published as part of a feature service, but that seems like using a sledgehammer to hang a picture frame.
Correct it's just a sql table in database NOT a geodatabase. My end goal to to have a sql table with a common field with my feature layer and the two joined so I can label my feature layer using a field from the sql table since I'm not allowed to edit the feature layer.
Or is there a better way to achieve what I need to do? Thank you Rich.
Hi Helen,
Just to clarify, when you say "stand alone sql table base" are you referring to a table in a database and not a geodatabase? That is, a database that has not been registered as a geodatabase?
