I am receiving the following error when trying to publish a survey in Survey123
Publishing error code: 401 Error transferring https://survey123.arcgis.com/api/beta/xform2webform - server replied: Internal Server Error
Survey123 Connect Version: 2.3.24
Any help is greatly appreciated!
This issue should now be fixed:
https://community.esri.com/thread/198663-update-error-400-401#comment-703258
I've attached the xls form.
Okay. We're seeing the error you are reporting with external selects and have identified a fix that we're working on implementing right now. I just tried a basic cascading select example and am not getting that error. Can you share your XLS Form?
The survey does not have any external selects. The survey only has internal cascading selects.
Hi Kevin,
Does you survey have external selects?
