As seen today that ArcGIS Python API finally released I tried to test some functionality and saw that, at some point, I couldn`t import arcgis.features module as described in the guide from the page (Working with feature layers and features | ArcGIS for Developers).
Has anyone had this error? I`m not sure if it`s a bug or is something from my setup or install...
Ionut
Are you running the latest version of the ArcGIS Python API? The Features module was only introduced with the latest release, version 1.0.
arcgis.__version__
should report the version as '1.0'. You can use it to verify if you're using the latest version.
Hi Joshua,
Yes, you were right; I was testing the API from beta and forgot to upgrade ) now it`s perfect. Thank you!
Hello Rohit,
Yes, I forgot to upgrade from 0.3 version. Now everything it`s working perfect Thanks a lot!
