I ahve encountered a problem in ArcScene10. I am finding that where I have created a polygon shapefile and overlay it over an OS or LiDAR base map that the base map intrudes into the polygon so that only part of the polygon shows - see attacehd jpegs - the first shows the area with no vertical exaggeration, the second with X2 vertical exaggeration. Annoyingly I have looked through some jpegs I did years ago - in ArcScene9 I think - and this didn't happen whereas now it happens all the time! Has anyone found a similar problem and if so do they have a solution?
Thank you,
Mike
