I have a survey that is being developed that needs to use external choices to prompt follow on questions to the correct selection choice based on the previous answers. e.g. if they select yes, they have a few choices via select_one_external prompt, and then based on this answer, they are presented with appropriate select_one_external choices. This all seems to working as expected until I have an answer with a comma in the text. Doing some more research into this, it appears to create a csv file in the Media folder and calls this itemsets.csv. So I believe, because this is being turned into csv, the comma is messing the order up. Is there a way to keep the comma and enclose the text in quotes like you can with other csv files?
