I configured my dispatch map to be searchable by various layers. I can see each of the 4 layers properly configured when viewing the map details > Settings > Web Map Settings. I set it up to search 4 layers by a ProjectID attribute using the CONTAINS operator. I have saved the settings. When I open the Workforce project and try to create an assignment, I click the link to search the map and the search bar opens. However, the option to search my layers is not there. Normally in a web map when the search by layer functionality is configured, the search box has a dropdown beside it so you can select the layer you want to search. Regardless, I tried putting putting in my search string and no results are found. Why isn't the dispatch map honoring my search settings?
