If not is this functionality planned for a future release?
ichivite-esristaff mentions the use of a repeat for photos in this thread: Multiple Photos in Survey123
Is that what you are looking for?
I think so, I'll give it a shot. Thanks for the quick response.
I'm still having issues setting up a repeat with a related table to store multiple images. I have the relationship class built, and have published a feature service with that related table available in the feature service, but when trying to publish my survey from Survey123 connect with the repeat referencing the related table by name I get an error that says the table cannot be found in the feature service.
I am using a feature service published from an ArcGIS Server which is then registered with ArcGIS Online. I am not using a hosted feature service or Portal for ArcGIS. Is this a supported workflow? If so what do I need to do to correctly reference the related table in the repeat of Survey123?
Thank you for your help with this,
Did you ever get this solved? I am at the same road block currently.
