Hi everyone,
Now that the Material/Universal design components have moved to core QML controls, can you use them in AppStudio 1.4.18?
I have managed to color a rectangle but the theme and accent color is not working as expected.
In MyApp.qml:
import QtQuick 2.5
import QtQuick.Controls 2.1
import QtQuick.Controls.Material 2.1
import ArcGIS.AppFramework 1.0
App { width: 400
height: 640
Material.theme: Material.Light
Material.accent: Material.Blue
MaterialRectangle { }
MaterialRectangle.qml
import QtQuick 2.5
Rectangle { width: 400
height: 640
color: Material.color(Material.Teal)
Material.accent: Material.Yellow
property int theValue
Switch { id: switch1
x: 143
y: 161
text: qsTr("Switch") checked: theValue >= 50
enabled: theValue >= 50
Dial { id: dial
x: 108
y: 228
to: 100
value: theValue
onValueChanged: theValue = parseInt(dial.position * 100)
Label { anchors.centerIn: parent
text: theValue
font.pointSize: 35
SpinBox { id: spinBox
x: 130
y: 450
value: theValue
onValueChanged: dial.value = value
If I'm missing something, great. However, in the help from Qt it says that QQuickStyle needs to be set to ("Material"). Is this value the culprit? If not, is there a simple fix?
Material Style | Qt Quick Controls 2 5.8
Styling Qt Quick Controls 2 | Qt Quick Controls 2 5.8
Marika Vertzonis Shobana Suresh Stephen Quan any info would be greatly appreciated.
Cheers,
"Bruce"
