In ArcPro 2.6 (and 2.6.1), this code snippet will core dump (it works in 2.5). This is a much simplified version of a larger Add-In. Is this a known issue? Is there a way around this core dump (without altering the steps it requires)?
protected async override void OnClick()
await QueuedTask.Run(() =>
string mapName = $"Map-Copy";
//Get the map
MapProjectItem mapProjectItem = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(item => item.Name == "Map");
Map originalMap = mapProjectItem.GetMap();
// Make a copy of the map
Map newMap = MapFactory.Instance.CopyMap(originalMap);
newMap.SetName(mapName);
SpatialReference spatialReference = SpatialReferenceBuilder.CreateSpatialReference(6455);
// Get the map frame in the layout
LayoutProjectItem layoutProjectItem = Project.Current.GetItems<LayoutProjectItem>().FirstOrDefault(item => item.Name == "Layout");
Layout layout = layoutProjectItem.GetLayout();
MapFrame frame = layout.Elements.FirstOrDefault(e => e.Name == "Map Frame") as MapFrame;
//Set the map frame's map to the new copy
frame.SetMap(newMap);
// Change the spatial reference of the map
newMap.SetSpatialReference(spatialReference);
