Hi
after a while running the Jupyter Notebook on ArcGIS Pro 2.4.1 (Windows 10) on a cloned environment I geta Kernel error with the following message
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\site-packages\tornado\web.py", line 1699, in _execute
result = await result
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\site-packages\tornado\gen.py", line 742, in run
yielded = self.gen.throw(*exc_info) # type: ignore
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\site-packages\notebook\services\sessions\handlers.py", line 72, in post
type=mtype))
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\site-packages\tornado\gen.py", line 735, in run
value = future.result()
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\site-packages\notebook\services\sessions\sessionmanager.py", line 88, in create_session
kernel_id = yield self.start_kernel_for_session(session_id, path, name, type, kernel_name)
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\site-packages\notebook\services\sessions\sessionmanager.py", line 101, in start_kernel_for_session
self.kernel_manager.start_kernel(path=kernel_path, kernel_name=kernel_name)
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\site-packages\tornado\gen.py", line 209, in wrapper
yielded = next(result)
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\site-packages\notebook\services\kernels\kernelmanager.py", line 168, in start_kernel
super(MappingKernelManager, self).start_kernel(**kwargs)
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\site-packages\jupyter_client\multikernelmanager.py", line 110, in start_kernel
km.start_kernel(**kwargs)
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\site-packages\jupyter_client\manager.py", line 240, in start_kernel
self.write_connection_file()
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\site-packages\jupyter_client\connect.py", line 547, in write_connection_file
kernel_name=self.kernel_name
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\site-packages\jupyter_client\connect.py", line 212, in write_connection_file
with secure_write(fname) as f:
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\contextlib.py", line 81, in __enter__
return next(self.gen)
File "C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone_zvbn_02\lib\site-packages\jupyter_client\connect.py", line 102, in secure_write
with os.fdopen(os.open(fname, open_flag, 0o600), mode) as f:
PermissionError: [Errno 13] Permission denied: 'C:\\Users\\xyz\\AppData\\Roaming\\jupyter\\runtime\\kernel-9fe63dbc-8b8d-4bc1-98f9-1e8536e166bd.json'
The permission error at the end looks strange to me, because it is my user folder.
Any ideas?
Tim
