I made sure that it was shared with the agency and the group in my Content as answered by James T. and that didn't help.
Debby C
Hi Debra,
Are you using Enterprised portal or ArcGIS online? One thing you may want to try is delete the stakeholder view(back it up if needed) and unshare/reshare the survey to see if you can save the change. If you are still having issue, you might need to go Survey123 websiet>Survey>Settings>Versions>choose "Always use the latest version" and would probably need to republish the survey again to fix some internal issue.
We are using AGOL. I deleted the stakeholder. I think that worked. Having my customer try it again.
Thanks.
