Hallo,<\/P>
<\/P>
Ik heb de Land Records Meetup<\/A> video's bekeken en ze zijn tot nu toe een grote hulp geweest bij het migreren van onze gegevens naar een LGIM kadastrale fabric. Slechte COGO-waarden worden meerdere keren genoemd en het wordt aanbevolen deze te verwijderen, maar hebben ze het alleen over de afstanden (wat ik begrijp) of over de afstanden en<\/EM> de hoeken? <\/P><\/P>Bedankt!<\/P><\/BODY><\/HTML>
Anna,
Bad COGO values refer to both bearings and distances. What you describe does not happen directly within the parcel fabric editing environment, but it could happen in older legacy systems. Then when importing that data from those systems into the fabric, those "mismatch" values get imported into the parcel fabric. This will result in parcels with a poor parcel misclose.
The Parcel Fabric Quality Control add-in can help to find these cases and, optionally, recalculate the values based on a filter that you set up.
-Tim
The example given in the video is the "back lot problem". A line that was originally drawn in as 100 feet is now broken into two 50 foot sections by an adjoining lot. Kind of like this:
The original line would still have 100 in the distance field and that can throw off the measurement tools in the parcel fabric, as far as I can tell from the videos. I don't have any experience with them yet 😕
How do you determine what a bad COGO value is? That seems like it would be a good amount of analysis work in itself.
