I keep getting the error stating my list name is not in the choices sheet when it is. How do I fix this bug?
I took a closer look at your screenshot and what you are trying to do. You don't need a primary key / foreign key for your related table when using the begin repeat function. Survey123 uses the GlobalID that is built into the application and it will show up once you publish the survey.
These tables exist.
Are you trying to create a related records or do you have an existing related table?
How do you handle related records then? It was created from pulling in our Featured Service. They are all related to the LocationID field?
You can't have the same field names under "name"
I tried that. It still didn't work. So yes, I will continue to diss your boys.
How you gonna diss my boys when you're not even doing it right??
It is the square brackets around your list name. A select_one should look like this select_one Status. You will want to remove the square brackets from all of your lists.
