can anyone please help me to sort some problems in network analysis regarding the data
Sir, I'm working on modelling of route analysis of dehradun city (actually in network analysis tutorial of arcmap it is on Ex06 there in the tutorial they took stores as parameters but in my case as i am unable to find that data so I used institutions as parameters that I obtained through digitization) and that is the total error that is showing after creating the modal. As I am struck here can you please suggest me anything.
Your screen shot does not show the entire error message. And it is not clear what your model is doing. So it is not possible to say what is going on.
There are many reasons a route may not find a path. For example the network dataset is not built or fully connected. There could be restrictions that cause no path to be found. The locations may not have snapped to the network due to search tolerances, etc.
Are you able to solve a route through the UI without using the model?
Jay Sandhu
while doing network analysis i.e (creating the modal for route analysis) using the road network of dehradun city it is just showing this without any descriptionÂ
What kind of problem are you running into?
