Can I make a direct connection to our SQL Server enterprise geodatabases with API for Python? Does the API only work with AGOL or Portal?
Not directly. It is common for ArcGIS API for Python to be installed in a Python environment that also has ArcPy, and ArcPy provides the ability to make direction connections to databases, both regular and geo-enabled. Even if ArcGIS API for Python supported connecting directly to geodatabases, it would likely require or use ArcPy code, so adding that support doesn't add much value.
Thanks Joshua for the answer. I can use arcpy with Jupyter Notebook but do not get widgets for result display other than textual.
