Can this be updated for the new Appstudio version 2
Access Secured ArcGIS Layers in your App using Runtime · Esri/arcgis-appstudio-samples Wiki · GitHub.
Access secured layer with credentials saved in the app.
Karpa
Hi there,
Here is the working code using Runtime 100.1. The old code is using the Runtime 10.2.6. The new Runtime 100.1 got few changes as far as component names go. Plus now there is a new MapView component which is container for Map component. Please refer our samples which are based on the newer runtime. The new samples are available within the AppStudio Desktop and the github. For doc help please refer here. I hope this helps.
Nakul
import QtQuick.Controls 2.1 import QtQuick 2.3 import ArcGIS.AppFramework 1.0 import Esri.ArcGISRuntime 100.1 App { id: app width: 800 height: 532 Credential{ id:cred username: "user1" password: "user1" } ServiceFeatureTable { id: serviceFeatureTable url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire_secure_ac/FeatureServer/0" credential: cred } MapView{ anchors.fill: parent Map { id: map Basemap { ArcGISTiledLayer { url: "http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" } } FeatureLayer{ featureTable: serviceFeatureTable } } } }<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
