Is it possible to change the display format for the coordinates in the lower left corner of the Geopoint map window to display in decimal degrees rather than degrees decimal minutes? I realize that if you click on the coordinates they can be edited as decimal degrees, but my users would prefer to see them as DD.ddddddd at all times. I am also not able to please them pulling the coordinates via the pulldata() command since the coordinates are not visible as long as the Geopoint map is open.
