I'm creating a Python script to create a HTML document with the message containing HTML code in triple quotes. How would I go about formatting some of the text inside the triple quote?
I figured it out with a simple solution.
I exit the triple quotes with triple quotes then added my variables by using + "{}".format(row[0]) + then re adding triple quotes to continue the string.
mess with single and double quotes and escaping... at least in python 3
a <SPAN class="operator token">=</SPAN> <SPAN class="string token">""" \'hello\' said "the \"parrot\" """</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">)</SPAN> <SPAN class="string token">'hello'</SPAN> said <SPAN class="string token">"the "</SPAN>parrot" a <SPAN class="string token">' \'hello\' said "the "parrot" '</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
but if you want to keep the triple quotes then you have to single quote the triple quotes so that they appear but not affect the escaped quotes…
a <SPAN class="operator token">=</SPAN> <SPAN class="string token">'""" \'hello\' said "the \"parrot\" """'</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">)</SPAN> <SPAN class="string token">""" 'hello' said "the "parrot" """</SPAN> a Out<SPAN class="punctuation token">[</SPAN><SPAN class="number token">8</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'""" \'hello\' said "the "parrot" """'</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
simple ehh???
In the Python script below I'm creating an HTML document with a hyperlink to generate an email. How would I use formatting .format(row[0]) in the body section of the email?
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> datetime<SPAN class="punctuation token">,</SPAN> os arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN> points <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"***********"</SPAN> today <SPAN class="operator token">=</SPAN> datetime<SPAN class="punctuation token">.</SPAN>date<SPAN class="punctuation token">.</SPAN>today<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> dte <SPAN class="operator token">=</SPAN> today<SPAN class="punctuation token">.</SPAN>strftime<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'%m/%d/%Y'</SPAN><SPAN class="punctuation token">)</SPAN> dtep <SPAN class="operator token">=</SPAN> today<SPAN class="punctuation token">.</SPAN>strftime<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'%m%d%Y'</SPAN><SPAN class="punctuation token">)</SPAN> fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'Applicant'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Date_Final'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Email'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Permit_No'</SPAN><SPAN class="punctuation token">]</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>points<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'FinalizedApproaches'</SPAN><SPAN class="punctuation token">)</SPAN> f<SPAN class="operator token">=</SPAN> open<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Finalized_{}.html"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>dtep<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"w+"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>points<SPAN class="punctuation token">,</SPAN> fields<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Date_Final = CURRENT_DATE"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN> message <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN>"<SPAN class="operator token"><</SPAN>!DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> table <SPAN class="punctuation token">{</SPAN> font<SPAN class="operator token">-</SPAN>family<SPAN class="punctuation token">:</SPAN> arial<SPAN class="punctuation token">,</SPAN> sans<SPAN class="operator token">-</SPAN>serif<SPAN class="punctuation token">;</SPAN> border<SPAN class="operator token">-</SPAN>collapse<SPAN class="punctuation token">:</SPAN> collapse<SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> td<SPAN class="punctuation token">,</SPAN> th <SPAN class="punctuation token">{</SPAN> border<SPAN class="punctuation token">:</SPAN> 1px solid <SPAN class="comment token">#dddddd;</SPAN> text<SPAN class="operator token">-</SPAN>align<SPAN class="punctuation token">:</SPAN> left<SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> 8px<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> tr<SPAN class="punctuation token">:</SPAN>nth<SPAN class="operator token">-</SPAN>child<SPAN class="punctuation token">(</SPAN>even<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> background<SPAN class="operator token">-</SPAN>color<SPAN class="punctuation token">:</SPAN> <SPAN class="comment token">#dddddd;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>h2<SPAN class="operator token">></SPAN>Notification Report<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>h2<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>table<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>tr<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>th<SPAN class="operator token">></SPAN>Customer<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>th<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>th<SPAN class="operator token">></SPAN>Status<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>th<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>th<SPAN class="operator token">></SPAN>Date<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>th<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>th<SPAN class="operator token">></SPAN>Email<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>th<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>tr<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>tr<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>td<SPAN class="operator token">></SPAN>Test Name<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>td<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>td<SPAN class="operator token">></SPAN>Finalized<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>td<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>td<SPAN class="operator token">></SPAN><SPAN class="number token">08</SPAN><SPAN class="operator token">/</SPAN><SPAN class="number token">30</SPAN><SPAN class="operator token">/</SPAN><SPAN class="number token">2018</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>td<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>td<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN>a href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"mailto:</SPAN><A class="jive-link-email-small" href="mailto:test@email.com" rel="nofollow noopener noreferrer" target="_blank">test@email.com</A><SPAN>&subject=Permit Status: Finalized&body={}"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="operator token">%</SPAN><SPAN class="number token">0D</SPAN><SPAN class="operator token">%</SPAN>0AThis <SPAN class="keyword token">is</SPAN> to notify you that your approach has been finalized<SPAN class="punctuation token">.</SPAN> Please use the link below to view your permit documentation<SPAN class="punctuation token">.</SPAN><SPAN class="operator token">%</SPAN><SPAN class="number token">0D</SPAN><SPAN class="operator token">%</SPAN><SPAN class="number token">0A</SPAN><SPAN class="operator token">%</SPAN><SPAN class="number token">0D</SPAN><SPAN class="operator token">%</SPAN>0Ahttps<SPAN class="punctuation token">:</SPAN><SPAN class="operator token">//</SPAN>www<SPAN class="punctuation token">.</SPAN>arcgis<SPAN class="punctuation token">.</SPAN>com"<SPAN class="operator token">></SPAN>Notify<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>a<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>tr<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>table<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="string token">""</SPAN>" f<SPAN class="punctuation token">.</SPAN>write<SPAN class="punctuation token">(</SPAN>message<SPAN class="punctuation token">)</SPAN> f<SPAN class="punctuation token">.</SPAN>close<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"{} Finalized report generate"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>dte<SPAN class="punctuation token">)</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
did you try some of the suggestions for formatting within the triple quote?
What did your code produce
I tested your suggestions and it still just produces {} in the body of the email.
perhaps you will have to google, …. html email python
I don't think it is just the triple quotes
For example
Sending HTML email using Python - Stack Overflow
I'm really just looking to have an email composed based on a fields from a search cursor using python but I want to be able to send it manually.
a and b would be inputs from your cursor???
Sorry, but maybe Joe Borgione might have had to do email notification or knows someone that does
a <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Hey folks..."</SPAN> b <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"\n</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwww.python.org" target="_blank">http://www.python.org</A><SPAN>"</SPAN></SPAN> t <SPAN class="operator token">=</SPAN> <SPAN class="string token">"{}\nHow are you?\nHere is the link you wanted:{}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> b<SPAN class="punctuation token">)</SPAN> h <SPAN class="operator token">=</SPAN> <SPAN class="string token">"""\ <html> <head></head> <body> <p>{} How are you?<br> Here is the link you wanted. {} </p> </body> </html> """</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> b<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"{}\n{}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>t<SPAN class="punctuation token">,</SPAN> h<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> Hey folks<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> How are you? Here <SPAN class="keyword token">is</SPAN> the link you wanted<SPAN class="punctuation token">:</SPAN> http<SPAN class="punctuation token">:</SPAN><SPAN class="operator token">//</SPAN>www<SPAN class="punctuation token">.</SPAN>python<SPAN class="punctuation token">.</SPAN>org <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>p<SPAN class="operator token">></SPAN>Hey folks<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> How are you?<SPAN class="operator token"><</SPAN>br<SPAN class="operator token">></SPAN> Here <SPAN class="keyword token">is</SPAN> the link you wanted<SPAN class="punctuation token">.</SPAN> http<SPAN class="punctuation token">:</SPAN><SPAN class="operator token">//</SPAN>www<SPAN class="punctuation token">.</SPAN>python<SPAN class="punctuation token">.</SPAN>org <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>p<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
