Can the area value of a geoshape type be used in a calculation for another field?
We need to determine the area of any polygon created and set that value on another field.
Survey123 Connect v3.3.51
Hi James,
Sure can! You can use the area() function in a calculation field for another question. This example shows the area (in square metres) and perimeter (in metres) of a polygon being converted to hectares and kilometres and rounded to 2 decimal places.
Brett
I have a geoshape within a repeat, I can easily return the area of the geoshape in square feet within another question in my survey with the area function if I add a single geoshape polygon using this calculation:
if(${dstrb_area},area(${dstrb_area})*10.7639, 0)
If I add two geoshapes in the repeat the calculation completes for the second of the two rather than for both.
How would I go about calculating the sum of two or more polygons collected in the geoshape repeat?
Thanks Brett, I could manage it and get polygon well. May I know same questions that I would like to know Sq Meter from this polygon for calculation If you don't mind can you please share me. Thanks.
Hello Thant Zaw Oo,
You can achieve this by putting your geopoint questions within a repeat. Then just use the sum() function in your geoshape question in the calculate column to build the polygon from the points in your repeat. I suggest joining the Early Adopter Community (if you haven't already) where you can find more detailed explanations on this beta functionality. Here is an example of setting up your XLSForm:
Hope this helps,
Hello Brett Stokes
I have multiple GPS points. Can I do manually type with Multiple GPS Points to create a polygon in geoshape? If we can create a polygon let me know how to create it
Score! Thanks so much for the example!
