Hi ForumI have a versioned database, where I want to make short lines longer. So in Python I try to select the short lines like this >>> uCursor = arcpy.da.UpdateCursor(inFeatures, [ 'OID@', 'SHAPE@', 'GM_LABEL', 'GM_USER_DEF' ], 'SHAPE@LENGTH < 300' ) edit = arcpy.da.Editor(arcpy.env.workspace) edit.startEditing() edit.startOperation()
which goes without problems but online = uCursor.next()
I get this error Runtime error Traceback (most recent call last): File "<string>", line 1, in <module> RuntimeError: Underlying DBMS error [ORA-04054: databaselink LENGTH does not exist ] [G100.geopoint_line]
I tried also this where clause, that works in ArcMap Select by attributes:SHAPE.LEN < 300
Because there is also a field called SHAPE.LEN.I tried with and without quotes with no success.Is it possible at all to make a constraint based on geometry?/Marianne
