I want to add a scale bar on my app. Can someone guide me? I am making my apps using arcgis runtime 100.1
The scalebar from ArcGIS.AppFramework.Runtime.Controls 1.0 is based on Runtime 10.2.6 and not for 100.1.
Unfortunately, there is no official implementation available for the scalebar at Runtime100.1. Runtime hasn't provided one yet. It is in the pipeline for future release.
Hence you have to create your own. This requires some work. Also mapScale property is now a property of MapView instead of Map.
This is just an example to get started. It is not a complete implementation.
Create a new qml as ScaleBar.qml
import QtQuick 2.2 import Esri.ArcGISRuntime 100.1 Item { id: scaleBar property MapView map: null signal clicked() signal doubleClicked() implicitWidth: 100 implicitHeight: 50 width: 100 height: 50 Component.onCompleted: { if (!map && parent && parent.objectType && parent.objectType === "MapView") { map = parent; } } QtObject { id: internal property real segmentWidth: scaleBar.width / 4 property real segmentHeight: scaleBar.width * 0.05 } Column { width: parent.width spacing: 0 Text { id: scaleText width: parent.width text: "1:" + Math.round(map.mapScale).toLocaleString() horizontalAlignment: Text.AlignHCenter elide: Text.ElideRight font { pointSize: 10 bold: true } } Item { width: parent.width height: internal.segmentHeight * 2 Column { id: segmentsColumn anchors.fill: parent Repeater { model: 2 Row { id: segmentRow property int rowIndex: index Repeater { model: 4 Rectangle { width: internal.segmentWidth height: internal.segmentHeight color: (index + segmentRow.rowIndex) & 1 ? "white" : "black" } } } } } Rectangle { anchors { fill: segmentsColumn } color: "transparent" border { color: "black" } } } Row { width: parent.width Repeater { model: 3 Text { text: "d" + index width: parent.width / 2 horizontalAlignment: Text.AlignLeft font { pointSize: 10 bold: true } } } } Text { width: parent.width text: qsTr("units") horizontalAlignment: Text.AlignHCenter elide: Text.ElideRight font { pointSize: 10 bold: true } } } MouseArea { anchors.fill: parent onClicked: { scaleBar.clicked(); } onDoubleClicked: { scaleBar.doubleClicked(); } } } <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
In your app add this Scalebar
ScaleBar{ anchors.left: mapView.left anchors.bottom: mapView.bottom anchors.margins: 10 * scaleFactor map:mapView }<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
For units you can use
map.spatialReference.unit.displayName. Some more work needs to be done to calculate d0, d1, d2 values to change dynamically. You can choose to work more on this or wait until the official implementation from Runtime becomes available.
No it doesn't. QT creater shows no information on scale bar. Also this is the scale bar I get - which shows no information.
I also feel that import ArcGIS.AppFramework.Runtime.Controls 1.0 is not entirely compatible with arcgis runtime 100.1
I will share the formal doc as soon as I find it, in the mean time though - does F2 on the "ScaleBar" work for you in Qt Creator IDE? That should take you to the source - ScaleBar.qml.
Thanks Kaushik,Can you please tell me where I can find the documentation for this? I'd like to tweak it a bit.
Hi Aneequa,
It's implemented in the Runtime.Controls lib or namespace.
So import ArcGIS.AppFramework.Runtime.Controls 1.0 in your qml file first
and implement as below along with desired supported properties and behaviour on the scalebar
For example:
ScaleBar {
anchors {
left: parent.left
leftMargin: 40
bottom: parent.bottom
bottomMargin: 55
map: safetyAlertMap
visible: true
