Hi there, I have prepared a mmpk with ArcGIS Pro 1.2 and shared it out to my AGOL organisation. Would like to know onthe steps to get it into my Navigator for ArcGIS. Thanks!
Hi Lee,
Although you can make MMPKs in ArcGIS Pro 1.2 or later, they are not supported in Navigator for ArcGIS yet. They will be usable in Navigator in a future release.
Best,
Emily
They do work in Version 1.3, although it may take several hours, in my case between 9 hours and 33 hours. Then, use Share Package to put them on ArcGIS Online, and Navigator will see them. Portal will host the files, but you will only see them either when looking at your uploaded files, or while on the phone in Navigator. You will be able to see the files once you are signed in.
Thanks Jay, you are correct that MMPKs are supported in Pro 1.3. They are actually supported in Pro 1.2 as well, and any version after that. You are also correct that Navigator for ArcGIS 2.0 or later now supports the use of custom MMPKs.
I'm wondering, what took between 9 and 33 hours? Just running the Create Mobile Map Package geoprocessing tool? Or the whole process of making an MMPK, from start to finish?
Just running the tool.
Okay, thanks for clarifying Jay!
Hey Jay,
One thing you can try is creating a new Pro project and adding only the items you need to create your Mobile Map Package to that project. I've noticed that building packages in projects that have had a lot of past traffic can really slow things down. If this is the case, you might notice that simply opening the Create Mobile Map Package tool in your current project takes longer than expected.
Joel
Has anyone else put them on ArcGIS Online and you still cannot see them in Navigator?
Lauren,
Can you please make sure that your .mmpk has a network in it, and a geocoding locator in it? if either is missing, it will not appear in Navigator search.
It was the address locator! But now, my network doesn't show up in Navigator, i was able to download it and the thumbnail shows it, but its not part of the map. I wonder if the fact that I don't have a time attribute is affecting it.
I will try this patch to see if it helps: ArcGIS 10.3.1 for (Desktop, Engine, Server) Geocoding General Maintenance Patch. http://support.esri.com/download/2252
