Is there any way to capture the mouse movement over a MapView?
The mousePositionChanged signal documentation is slightly mis-leading, because it only fires when the mouse button is held down while the mouse is moved. I'm looking for a signal similar to the onPositionChanged signal of a MouseArea.
I tried placing a MouseArea over my mapview, but then nothing propagates through to the MapView, i.e. can't pan or click (although mouse wheel zooming seems to work!?). I tried manually triggering all the MapView mouse signals (e.g. whenever the mouse area pressed signal fires I called mapView.mousePressed(mouse) etc) but still couldn't pan/move the map around.
So I guess I'm asking for either of two things:
1) a way to capture the mouse hover movement over a MapView so I don't have to use a MouseArea at all (my preference)
2) a way to place a MouseArea over a MapView to capture the mouse hover movement but still be able to navigate the map underneath.
Emitted when the mouse is moved over the GeoView.
