How to I set parameters in ArcGIS Pro to find nearest facilities and show drive times? I need to also determine where I input the starting point, i.e. "show all post offices within a 10 minute drive time of x".
Hi Dan, yeah, I was trying to add in the street network data as per the attached snapshot…
don't drag and drop stuff... especially the part about the template
Did you follow these instructions from the first page?
The data for this tutorial is available for download on arcgis.com.
A new project with a map appears.
Hi again,
I am unable to successfully connect to the training data and display. After connecting to the transportation folder and attempting to “drag and drop” the data into the map, I receive an error message (attached) about upgrading my ArcGIS metadata.
Chuck
This looks along the lines of what I need Dan. I hadn’t seen the tutorial before, so let me give that a try. Thanks!
are you trying to follow or emulate the closest facilities tutorial?
