For some reason since today I have not been able to generate a single feature report from Survey123, it give me an error "Internal server-side error" every single time.
I have generated the same report yesterday just fine but no luck today.
Hi ALL,
To whom it encountered the "Internal server-side error." or "Render expression is: ${undefined}", we updated the beta website https://survey123beta.arcgis.comwith a potential fix to this issue, would you mind trying on the beta website to see if it works for you? The fix will be applied to the Survey123 website https://survey123.arcgis.com late this week.
Thanks for all your feedback!
The fix to the "Internal server-side error" and "Uploading...0%" issues is available on Survey123 website https://survey123.arcgis.com now.
Thank you all for your feedback.
Hi All,
The fix of "supportsPagination" bug is on https://survey123.arcgis.com.
Jody Zheng Liu
The issue appears to be related to additional features that have been added to the Survey over the period of this year. When I produce feature reports from the end of last year on older Surveys they are able to be generated just fine. But when I use the newest Surveys that used to generate feature report 2 days ago it then give me the same Internal Server-side Error. Not sure if it’s due to new incompatible, off the top of my head JavaScript has been added and some other minor fields that calculates.
is anyone else having this issue, not able to generate reports?
Beginning on Thursday, 7/2/20 our Feature Reports are no longer working either. I'm assuming this is because of the changes that were made to the Survey123 report features by ESRI. I don't know what's different or incompatible, I get the same Internal Server Side error message. I tried creating a new sample template from a submitted survey and that did not work either, so it's not something that's specific to my customization - the ESRI generated sample report does not work and returns the same error. This is a huge problem that needs to be fixed ASAP.
After doing some further testing, it appears that whatever changes were made are not respecting multiple sections in the template. Each of these sections contains repeats.
For example - this works:
However, if I add on another section to the template like what's shown below, then it fails:
That is correct. If I generate a sample template and I use it to generate a Feature Report it still give the same error, even when I try do "Review sample report", or Generate in the format of "Microsoft Word (.docx), or Portable Document Format (.pdf) they all fail the same way.
Hi EnelGreenPowerNA,
Thanks for the additional information, this helps understand the issue. We're looking into this and will get back once we notice something.
Zhifang
Hi Christopher Van de Wyngard,
Would you mind sharing us a screenshot after clicking the "Show details" link button and also together with the Recent tasks panel expanded? Or a Job ID of your failed task would also help.
Here is a copy of the "Show details" of the error.
I also found out that if I remove all of our repeats groups and only leave one on the Feature Report template, it works.
If I have two or more repeats groups then it gives me the same error.
We have a total of 4 repeats groups, so this is definitely an issue.
Please let me know what you are able to find out from your ends why the repeats are creating such error.
I'm having the same issues on at least two projects. Maybe some of these details will help:
Let me know if there are any further details that'd be helpful, or anything additional I should test.
I also have this issue. My survey is pretty basic in that it was created in connect for this purpose only and does not reference any outside resources. It has two stand alone repeats, one for images and one to submit a listing of near-by plants at the site. If I remove one of the repeats from the report it runs just fine but both of the repeats are necessary to get the results of the survey.
The patch worked for my survey's report- Thank you.
Hi Zhifang,
Yes - that works on the beta site. Hopefully this can be applied to the production site ASAP.
The beta site doesn't fix "supportsPagination" bug, see here for details: https://community.esri.com/thread/256233-survey123-feature-report-anticipated-fix
We really need to get this working!
Almost 4 years later i seem to be running into the exact same problem. Does anyone else seem to have this issue?
Just got it today here in Virginia Beach
I received this error this morning also. No previous issues on surveys and Make scenarios that were working yesterday.
Also running into this error on our Survey123 Portal accounts on all surveys.
Getting this error today as well with enterprise 10.9.1
Hoping that @ZhifangWang might have some insight since they provided help on the original issue.
Exact same issue here.
Same version, same issue.
Started getting this error too since 15:00 NZST yesterday (10/09/2024). Reports were still generating hours before. We're on Portal 10.8.1
Same issue here, im from Porto Alegre, Brazil. The error appeared since 09/09/2024, only on the enterprise
I did get word from the analyst I was working with that an update was made Sep 10th, 2024. They have logged the defect, but no word on a resolution yet. https://doc.arcgis.com/en/survey123/get-started/whatsnewsurvey123.htm
Thanks, I also heard this. There is some action over here: https://community.esri.com/t5/arcgis-survey123-questions/internal-server-side-error-reports/td-p/1336585/page/3
"Tech Support has logged BUG-000170665 for this."
