Hi all,
I've been trying to perform what seems like it should be a fairly simple task, but I've been unable to get it to work using the simple "dummy" versions of the data I have, so I figured I'd ask here.
Essentially, I need to know the volume of sediment excavated in each level of several archaeological units. The units themselves are either square or rectangular pits, but the tricky part is that each level has irregular starting and ending depths. I have XYZ coordinates for the four corners and center point of each level. While the XY coordinates of those points remain essentially unchanged throughout the unit, the Z coordinates are different even for the top or bottom of the same level (because unfortunately we're less-than-perfect excavators, as it turns out). I'm trying to quickly turn these points into 3D
