Can a Survey be hosted locally on my own server rather than on AGOL?
If so, can the public access it?
Thanks.
Hi John,
Did you see the response to your earlier thread?
Host survey123 on Enterprise
James Tedrick said:
Hi John, There is currently partial support for Survey123 with ArcGIS Enterprise. In particular, Survey123 Connect and the Survey123 field application can connect to an ArcGIS Enterprise installation, use Portal to store the form information and use the Data Store to store survey data. The Survey123 website cannot yet be configured to work with an ArcGIS Enterprise installation; we are working on supporting both configuring the survey123.arcgis.com website to connect to a portal as well as an on-server installation capability. In another post, you asked about public surveys. Just to note, the surveys published into an ArcGIS Enterprise installation are limited by the network accessibility of the installation - if your Portal and Data Store are not publicly visible on the internet, you can't have a public survey (a 'public' survey in that case would be limited to people inside your company's network).
