ArcGIS for AutoCAD; AutoCAD 2015. Can anyone say me when is it going to release..??? as none of the arcgis versions are compatable with the 2015 autoCAD version..
The latest release of ArcGIS for AutoCAD (release date: September 2014) supports ArcGIS for AutoCAD 2013, 2014, and 2015.
ArcGIS for AutoCAD | Download
Thanks for the answer but i want to know when will 2015-16 released..??
The current release ArcGIS for AutoCAD already support AutoCAD 2015. Early tests show that ArcGIS for AutoCAD 350 also works unmodified on AutoCAD 2016 although the next release due this summer will be certified on 2016.
Hi, I currently downloaded and install Esri for Autocad 2015, the file name says Autocad 2013 anyway. I didn't think that was the problem, but after the installation I open my Autocad 2015 and I don't see any change. Do i have to activate something later?
Could it be as simple as loading the ArcGIS for AutoCAD plugin DLL
During an AutoCAD session, you can load ArcGIS for AutoCAD with the NETLOAD command.
Steps:
or more permanent solution
I'm using ArcGIS for AutoCAD with AutoCAD 2016 and no issues whatsoever. This is build 350.
Could you please tell me how to export the feature classes (local) which is created. along with attributes.
In ArcCatalog, navigate to the DWG containing the feature class and then export the feature class to a shapefile.
Navaneetha,
Depending on what you intend to do with the .DWG you may not need to export anything.
ArcGIS Desktop (ArcCatalog/ArcMap/ArcGIS Pro) will read the DWG you’ve created with local feature classes as an ArcGIS dataset with those feature classes and attributes.
If you want to create a shapefile or copy the data to a geodatabase you certainly could also do that in Desktop with any GP tool or other method that copies GIS data (since the local feature classes in the DWG already are a GIS data set with attributes etc.)
-Don
Some time's need to save the drawing once again in some other path for exporting the feature classes, in the original drawing where feature class (local) is created is not visible in catalog.
Otherwise it is good.
Is there any other tool to update the field in the feature class (local) automatically
Is it possible to access WMS or WFS service rather than Arc server rest api's.
Navanetha,
No ArcGIS for AutoCAD, does not support WMS or WFS, it is a free client of ArcGIS Web Services which have more capabilities than their OGC counterparts especially within the ArcGIS System.
