I have made 3 versions according to ArcGIS help. I have "Default", "Cases" and "Case1" versions. I expect that case1 version send its changes to Cases version but it sends them directly to Default version. What should I do?
In version manager, did you make Case1 to be a child of Case? If Case1 is posting directly to Default, that means it's a child of Default.
Thanks for your response. I followed the ArcGIS help and I attached a image of version manager . Please look at it and mention your idea. Thanks in advance
Can you take a complete screen shot of the Geodatabase Administration screen showing your versions? When you click on a version it will report the parent of the version. In order to create a child of a SPECIFIC version your mouse pointer must BE ON that version when you right-click and select new version, as pictured below. Also, what version of Arc are you using, what version of SQL, what operating system, etc...?
I am connecting to SQL Server using "direct connection" ( not using Database Server). I use ArcGIS10, SQL server 2008. I could not find Geodatabase Administrator.
