I have published two layers. One containing points and the other containing polygons.I would like to count the number of points belonging to a polygon when the user clicks it using ArcGIS Javascript API. I have already done the functionality of highlighting the polygon when the user clicks it. Now I want that an alert message will show up with the number of features in that polygon when the polygon is clicked. I already tried to do some code but its not giving the correct answer. function selectByCouncil() { var localCouncils = new FeatureLayer("feature layer with polygons", { mode: FeatureLayer.MODE_SNAPSHOT, outFields: ["*"] }); map.addLayer(localCouncils); var highlightSymbol = new SimpleFillSymbol( SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 1), new Color([125, 125, 125, 0.35]) ); map.on("load", function () { map.graphics.enableMouseEvents(); }); localCouncils.on("click", function (evt) { map.graphics.clear(); var highlightGraphic = new Graphic(evt.graphic.geometry, highlightSymbol); map.graphics.add(highlightGraphic); var query = new Query(); var queryTask = new QueryTask(feature layer with points); query.geometry = evt.graphic.geometry; query.returnGeometry = true; var countOfFeatures = 0; queryTask.execute(query, function (results) { dojo.forEach(results.features, function (feature) { countOfFeatures++; }); alert("Number of points in polygon " + countOfFeatures); }); }); }Any ideas on how this could be done are much appreciated. Thanks
