How do I hide labels for fields with image types? Survey123 Connect won't allow me to keep the label field empty.
I found my solution. If I use the html code below and keep the text >< empty the program doesn't prompt and errors.
Just adding a side note for the noobs (like me). This HTML script is added to the 'label' column at the 'survey' worksheet of your XLSForm. And you can simply use:
Thanks for this Jordan!
