I have a published survey with over a 100 records already collected, however the data is not displaying correctly in the data tab online. I am now concerned that a reason for this could be that the survey was published with field names that contain reserved words (from & to).
Is there a way to go back in to the survey and amend these fields in the schema without losing the data already collected? If I amended them in connect they simply get added as a new field, leaving the old field still in the survey, so the problem still occurs.
Any help would be greatly appreciated.
Martyn
