I create a Spatial Dataframe with a line geometry in it. This should be published as a Feature Layer on ArcGIS Online but a error occures.
1. Create a line geometry and add it to a list.
line <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"paths"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">97.06138</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">32.837</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">97.06133</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">32.836</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">97.06124</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">32.834</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">97.06127</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">32.832</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">97.06326</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">32.759</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">97.06298</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">32.755</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"spatialReference"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">"wkid"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN><SPAN class="punctuation token">}</SPAN>
polyline <SPAN class="operator token">=</SPAN> geometry<SPAN class="punctuation token">.</SPAN>Polyline<SPAN class="punctuation token">(</SPAN>line<SPAN class="punctuation token">)</SPAN>
listGeometries <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
listGeometries<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>polyline<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>2. Create a pandas dataframe with additional information.
d <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">'col1'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"abc"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'col2'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">123</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">}</SPAN>
df <SPAN class="operator token">=</SPAN> pd<SPAN class="punctuation token">.</SPAN>DataFrame<SPAN class="punctuation token">(</SPAN>d<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>3. Create a Spatial Dataframe and a Feature Layer from this.
spatialDataFrame <SPAN class="operator token">=</SPAN> fs<SPAN class="punctuation token">.</SPAN>SpatialDataFrame<SPAN class="punctuation token">(</SPAN>data<SPAN class="operator token">=</SPAN>df<SPAN class="punctuation token">,</SPAN> geometry<SPAN class="operator token">=</SPAN>listGeometries<SPAN class="punctuation token">)</SPAN>
spatialDataFrameLayer <SPAN class="operator token">=</SPAN> spatialDataFrame<SPAN class="punctuation token">.</SPAN>to_featurelayer<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"LineFeatureLayer"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
This error message occures.
---------------------------------------------------------------------------KeyError Traceback (most recent call last)<ipython-input-69-74d83f9ecb21> in <module>()----> 1 spatialDataFrameLayer = spatialDataFrame.to_featurelayer("MarienplatzProjected") 2 #spatialDataFrameLayer = spatialDataFrame.to_featureset()~\AppData\Local\Continuum\Anaconda3\envs\arcgis\lib\site-packages\arcgis-1.3.0-py3.5.egg\arcgis
\features\_data\geodataset\geodataframe.py in to_featurelayer(self, title, gis, tags) 899 raise ValueError("GIS object must be provided") 900 content = gis.content--> 901 return content.import_data(self, title=title, tags=tags) 902 #---------------------------------------------------------------------- 903 def set_geometry(self, col, drop=False, inplace=False, sr=None):~\AppData\Local\Continuum\Anaconda3\envs\arcgis\lib\site-packages\arcgis-1.3.0-py3.5.egg\arcgis
\gis\__init__.py in import_data(self, df, address_fields, **kwargs) 2332 uuid4().hex[:5]) 2333 ds = df.to_featureclass(out_location=temp_dir,-> 2334 out_name=name) 2335 zip_shp = zipws(path=temp_dir, outfile=temp_zip, keep=False) 2336 item = self.add( ~\AppData\Local\Continuum\Anaconda3\envs\arcgis\lib\site-packages\arcgis-1.3.0-py3.5.egg\arcgis
\features\_data\geodataset\geodataframe.py in to_featureclass(self, out_location, out_name,
overwrite, skip_invalid) 616 out_location=out_location, 617 out_name=out_name,--> 618 overwrite=overwrite, skip_invalid=skip_invalid) 619 #---------------------------------------------------------------------- 620 def to_hdf(self, path_or_buf, key, **kwargs):~\AppData\Local\Continuum\Anaconda3\envs\arcgis\lib\site-packages\arcgis-1.3.0-py3.5.egg\arcgis\
features\_data\geodataset\io\fileops.py in to_featureclass(df, out_name, out_location, overwrite, out_sr, skip_invalid) 382 return _pyshp_to_shapefile(df=df, 383 out_path=out_location,--> 384 out_name=out_name) 385 else: 386 raise Exception("Cannot Export the data without ArcPy or PyShp modules. "+ \ ~\AppData\Local\Continuum\Anaconda3\envs\arcgis\lib\site-packages\arcgis-1.3.0-py3.5.egg\arcgis
\features\_data\geodataset\io\fileops.py in _pyshp_to_shapefile(df, out_path, out_name) 90 shpfile.poly(geom['rings']) 91 elif geom.type == "Polyline":---> 92 shpfile.line(geom['path']) 93 elif geom.type == "Point": 94 shpfile.point(x=geom.x, y=geom.y)KeyError: 'path'It seams, as the "paths" key in the first code snippet is the problem, because a "path" key is required. But if the "paths" is changed to "path" the line geometrie is nod valid anymore.
How can I publish valid line geometries as a Feature Layer?
rsingh-esristaff
