I am trying to split a fist and middle name. the number of names is not always two:
How can I split these into two columns?
You could use enumerate
<SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> names <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="string token">"WILLIAM LEWIS"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="string token">"SAMMY L"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="string token">"ROCKY"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="string token">"ORA SETH"</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="keyword token">for</SPAN> name <SPAN class="keyword token">in</SPAN> names<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> f_m <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="operator token">*</SPAN><SPAN class="number token">2</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">for</SPAN> i<SPAN class="punctuation token">,</SPAN>n <SPAN class="keyword token">in</SPAN> enumerate<SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> f_m<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+=</SPAN> n <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"First name is '{}' and middle name is '{}'"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN><SPAN class="operator token">*</SPAN>f_m<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> First name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'WILLIAM'</SPAN> <SPAN class="operator token">and</SPAN> middle name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'LEWIS'</SPAN> First name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'SAMMY'</SPAN> <SPAN class="operator token">and</SPAN> middle name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'L'</SPAN> First name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'ROCKY'</SPAN> <SPAN class="operator token">and</SPAN> middle name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">''</SPAN> First name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'ORA'</SPAN> <SPAN class="operator token">and</SPAN> middle name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'SETH'</SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
or zip_longest
<SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="keyword token">from</SPAN> itertools <SPAN class="keyword token">import</SPAN> zip_longest <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> names <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="string token">"WILLIAM LEWIS"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="string token">"SAMMY L"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="string token">"ROCKY"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="string token">"ORA SETH"</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="keyword token">for</SPAN> name <SPAN class="keyword token">in</SPAN> names<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> first<SPAN class="punctuation token">,</SPAN> middle <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>f<SPAN class="operator token">+</SPAN>m <SPAN class="keyword token">for</SPAN> f<SPAN class="punctuation token">,</SPAN>m <SPAN class="keyword token">in</SPAN> zip_longest<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="operator token">*</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> name<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> fillvalue<SPAN class="operator token">=</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"First name is '{}' and middle name is '{}'"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>first<SPAN class="punctuation token">,</SPAN>middle<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> First name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'WILLIAM'</SPAN> <SPAN class="operator token">and</SPAN> middle name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'LEWIS'</SPAN> First name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'SAMMY'</SPAN> <SPAN class="operator token">and</SPAN> middle name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'L'</SPAN> First name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'ROCKY'</SPAN> <SPAN class="operator token">and</SPAN> middle name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">''</SPAN> First name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'ORA'</SPAN> <SPAN class="operator token">and</SPAN> middle name <SPAN class="keyword token">is</SPAN> <SPAN class="string token">'SETH'</SPAN> <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
