we hebben enkele nieuwe plugin voorbeelden toegevoegd aan de Esri Leaflet website die renderers van ArcGIS Online tonen, toegang tot GP-services, en het tegelijkertijd doorzoeken van feature layers en map services terwijl je geocodeert...<\/SPAN><\/P>\n <\/P>\nEsri Leaflet Quickstart | Esri Leaflet<\/A>\/<\/SPAN><\/P>\n <\/P>\nveel plezier!<\/SPAN><\/P>
your geocoding service is returning a bogus extent.
http://gis.ccpa.net/arcgiswebadaptor/rest/services/CompositeLocator/GeocodeServer/find?text=1900+grantham+road&sourceCountry=&outFields=*&maxLocations=&bbox=&outSR=4326&f=html
you have a couple different options to resolve the problem:
1. figure out how to fix the locator itself
2. override the plugin behavior in your leaflet app to just center on the address and a fixed zoom level instead of relying on the extent your service is passing back.
John,
I've encountered a weird quirk with the Geocoding plugin for Leaflet. When I use the ESRI World Geocoder, the map zooms in to the results.
However, if I use my organization's geocoding service and have the ESRI geocoder turned off, the marker is placed at the right location, but the map zooms out to a multi-state view.
The sample codes is on Codeacademy. I couldn't get JS Fiddle to work.
Any help or direction pointing is most helpful.
Patrick
the closest available sample demonstrates how to plug in a MapService provider, but you could use similar logic to insert your own geocoding provider.
i'd be happy to review a jsfiddle or jsbin if you get stuck.
if we get a simple sample together, i think it would be nice to add it to our website.
The new samples are great! I was looking at the geocoding sample (here)... very cool! Do you guys have any plans for releasing a sample that shows how to integrate geocoding from a custom service instead of one from AGOL? Don't want to reinvent the wheel here if it's already on your list.
Thanks again!
