Good Day
I am currently experiencing issues with the pulldata() function, the survey is intended to assist with collecting movable assets information from various government departments. The information I am trying to pull is not populating in the survey, I am not sure what could be the problem. Please kindly assist. Attached is the .csv file that I've been attempting to pull from and also a screenshot of the survey.
Hi
Thank you so much from your prompt response, I will make the changes as suggested.
In your column with all the ; in there like this
BARCODE;SERIAL_NUMBER_PLATE;ASSET_DESCRIPTION;ROOMNUM;ROOM_DESCRIPTION;BUILDING;FLOOR;SITE_DESCRIPTION;RESPONSIBLE_PERSON;ASSET_CATEGORY_ID;CATEGORY;SUB_CATEGORY;SUB_CATEGORY_DESCRIPTION_FOR_DEPRECIATION;CONDITION
You have new line chars in there. That will kill you list. If you can remove this column I would. If not here is how to find new lines.
Open in Excel
Go to the column and select it
Right click Format Cells
Go to Alignment tab
Check Wrap Text
Now scroll through the list and you will see the new lines pop out at you.
To fix edit that row and delete anything before the first char and everything after. You of course will not see anything on the screen. But when you click away from the field you will see it change.
Issue number 2 is you have Commas in this field PROPERTY, PLANT AND EQUIPMENT. You cannot have ANY commas in the label field. It will cause you list to be all misplaced. Oh I see them in the 3rd column also COAT HANGER - HANGER STAND(STEEL,GREY). Again no commas anywhere.
These both get me a lot when others send me files. Not well documented.
