Hi I'm trying to create my own Network Analyst road network from scratch. How do i update that network after ? For example i want to added more polylines to my road network ? Like what do i do after editing the shapefile of the network ?
Thank you
The file is open in another application. close any application that you have open except arcmap, save the project and try again. If that doesn't work, close the project, and reboot.
i tried that but im getting an error and not sure how to fix this. i attached a picture of the error. Thank you inn advance
It sounds so simple Building a network dataset in ArcMap—Help | ArcGIS for Desktop and everything works.... unless you have geometry errors or other errors ... which you can recover if you read the comments in the script in this help topic thread Build Network—Help | ArcGIS for Desktop allowing you to determine what to do next
Yes but it's not working the system (Network Analyst) is not getting updated with the changes. It tells me to rebuild it but when i got on Arccatalogue and press rebuild it says "build network dataset failed"
Dit you already have a look at this topic in the Help: Ways to edit network datasets—Help | ArcGIS for Desktop
