Moved from ArcGIS for Server
Update:
i have 4 services that i am bring in to my cad document. one is polygon, one is line and two are point services.
When i add features and go to synchronize with my server i get the following message, twice
MyMapService: Errors encountered in adding features. error processing server request.
when its over it tells me that the only features that updated were to the line and polygons. the points failed to update. Oddly i can delete features tho.
anyways when i go to check the AGS logs i see the following
Message: Method failed.HRESULT = 0x80070057 : The parameter is incorrect. (more)
Tagert: Landscape/L_Site.Mapserver
Code: 100005
Method Name: GraphicFeatureServer.Add
So it seems the error only happens on my services that are point geometry.
Any thoughts?
original post:
So after adding features to my feature service layer in AutoCAD when i go to sync my edits back up to the server i get the following error
Code: 100005
Can any give some in-site as to what this means?
