Is there any method that can override the application's close event? For instance, when a user tried to close the application on Windows, will trigger that can add some logic. After some googling, I found that there's a way to implement in Qt (qt - QtQuick: how to override window close event? - Stack Overflow ) But, can't find any similar method in App / AppLayout QML.
Thanks.
Sean.
Sean,
In general QML, you can use the onClosing signal for Qt Window, Window QML Type | Qt Quick 5.13.2
But, this is not supported within the "App" of the AppStudio AppFramework. This is a good enhancement, we are looking into a way to add this into AppStudio AppFramework that would support all platforms. If this is a requirement for your app, I would recommend submitting a formal Enhancement request through Esri Technical Support, so that we can track it.
Thank you,
Erwin
Thanks for your answer, Erwin.
I will submit this through support as you guided due to it is one of our app's requirement.
Sean
We found something, but I think this might not be what you are looking for. This will not override the close event, but this is an event listener when the app is closed.
Erwin.
