Hi.
I would like to write a shapefile from a featureSet created after .query()
As you can see in the picture I have the featureSet, I cast it as a panda.DataFrame but then supposedly I should be able to use the method to_featureclass following the instructions from here: https://developers.arcgis.com/python/guide/introduction-to-the-spatial-dataframe/#Saving-Spatial-DataFrames
But my object does not have this method. I am really confused why it doesn't.
The only question similar to mine that I have found is this one: https://community.esri.com/message/824163-cant-export-spatialdataframe-to-shapefile But I am afraid it didn't help me.
Many thanks for any input.
Greta
Hi Greta,
You may have already figured this out, but it looks like you missed 'spatial' - it should read:
'xyz_sdf.spatial.to_featureclass'
I see this working with the below example script using version 1.6.2 of the API. This particular example maintains the source projection:
<SPAN class="keyword token">from</SPAN> arcgis <SPAN class="keyword token">import</SPAN> GIS <SPAN class="keyword token">from</SPAN> arcgis<SPAN class="punctuation token">.</SPAN>features <SPAN class="keyword token">import</SPAN> FeatureLayerCollection<SPAN class="punctuation token">,</SPAN> GeoAccessor<SPAN class="punctuation token">,</SPAN> GeoSeriesAccessor <SPAN class="keyword token">from</SPAN> arcgis<SPAN class="punctuation token">.</SPAN>geometry <SPAN class="keyword token">import</SPAN> SpatialReference <SPAN class="keyword token">import</SPAN> pandas <SPAN class="keyword token">as</SPAN> pd <SPAN class="keyword token">def</SPAN> <SPAN class="token function">search_item</SPAN><SPAN class="punctuation token">(</SPAN>conn<SPAN class="punctuation token">,</SPAN> item_name<SPAN class="punctuation token">,</SPAN> item_type<SPAN class="punctuation token">,</SPAN> flc<SPAN class="operator token">=</SPAN><SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> search_results <SPAN class="operator token">=</SPAN> conn<SPAN class="punctuation token">.</SPAN>content<SPAN class="punctuation token">.</SPAN>search<SPAN class="punctuation token">(</SPAN>item_name<SPAN class="punctuation token">,</SPAN> item_type<SPAN class="operator token">=</SPAN>item_type<SPAN class="punctuation token">)</SPAN> proper_index <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>i <SPAN class="keyword token">for</SPAN> i<SPAN class="punctuation token">,</SPAN> s <SPAN class="keyword token">in</SPAN> enumerate<SPAN class="punctuation token">(</SPAN>search_results<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="string token">'"'</SPAN> <SPAN class="operator token">+</SPAN> item_name <SPAN class="operator token">+</SPAN> <SPAN class="string token">'"'</SPAN> <SPAN class="keyword token">in</SPAN> str<SPAN class="punctuation token">(</SPAN>s<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN> found_item <SPAN class="operator token">=</SPAN> search_results<SPAN class="punctuation token">[</SPAN>proper_index<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">if</SPAN> flc <SPAN class="operator token">==</SPAN> <SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">:</SPAN> get_item <SPAN class="operator token">=</SPAN> conn<SPAN class="punctuation token">.</SPAN>content<SPAN class="punctuation token">.</SPAN>get<SPAN class="punctuation token">(</SPAN>found_item<SPAN class="punctuation token">.</SPAN>id<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN> get_item <SPAN class="keyword token">if</SPAN> flc <SPAN class="operator token">==</SPAN> <SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">:</SPAN> flc <SPAN class="operator token">=</SPAN> FeatureLayerCollection<SPAN class="punctuation token">.</SPAN>fromitem<SPAN class="punctuation token">(</SPAN>found_item<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN> flc <SPAN class="keyword token">def</SPAN> <SPAN class="token function">main</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> conn <SPAN class="operator token">=</SPAN> GIS<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"https://www.arcgis.com"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Username"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Password"</SPAN><SPAN class="punctuation token">)</SPAN> flc <SPAN class="operator token">=</SPAN> search_item<SPAN class="punctuation token">(</SPAN>conn<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Name_of_Feature_Layer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Feature Layer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN> layer <SPAN class="operator token">=</SPAN> flc<SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> epsg_code <SPAN class="operator token">=</SPAN> layer<SPAN class="punctuation token">.</SPAN>properties<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'extent'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'spatialReference'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'latestWkid'</SPAN><SPAN class="punctuation token">]</SPAN> feature_set <SPAN class="operator token">=</SPAN> layer<SPAN class="punctuation token">.</SPAN>query<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> sdf <SPAN class="operator token">=</SPAN> feature_set<SPAN class="punctuation token">.</SPAN>sdf srs <SPAN class="operator token">=</SPAN> SpatialReference<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">"wkid"</SPAN><SPAN class="punctuation token">:</SPAN>epsg_code<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN> sdf<SPAN class="punctuation token">.</SPAN>spatial<SPAN class="punctuation token">.</SPAN>project<SPAN class="punctuation token">(</SPAN>srs<SPAN class="punctuation token">)</SPAN> sdf<SPAN class="punctuation token">.</SPAN>spatial<SPAN class="punctuation token">.</SPAN>to_featureclass<SPAN class="punctuation token">(</SPAN>location<SPAN class="operator token">=</SPAN><SPAN class="string token">"/home/test.shp"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">if</SPAN> __name__ <SPAN class="operator token">==</SPAN> <SPAN class="string token">'__main__'</SPAN><SPAN class="punctuation token">:</SPAN> main<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
An alternative approach would be to use the fiona library instead of sdf to write the shapefile. The equivalent workflow is something like this:
Hope this helps!
-Earl
Hi Earl,
Apologies for my confusion and thank you so much for your detailed answer it is super useful!
I have managed to export the data.
Cheers.
