Ik maak een eenvoudige app om een leaflet-kaart te tonen met meteor. Maar het werkt niet. Dit is mijn code : Html:
<div id="viewDiv"> Explore D3 </div> </template> javascript:
onRendered(){ L = require('esri-leaflet') var map = L.map('viewDiv').setView([45.528, -122.680], 13); L.esri.basemapLayer("Gray").addTo(map); var parks = L.esri.featureLayer({ url: "http://gis.d3smartcity.ae/arcgis/rest/services/Operation_layers/d3_Masterplan/MapServer?f=jsapi", style: function () { return { color: "#70ca49", weight: 2 }; } }).addTo(map); var popupTemplate = "<h3>{NAME}</h3>{ACRES} Acres<br><small>Property ID: {PROPERTYID}<small>"; parks.bindPopup(function (e) { return L.Util.template(popupTemplate, e.feature.properties) }); }
Dadi,
One major issue is the url you are using for the featureLayer:
<SPAN class="keyword token">var</SPAN> parks <SPAN class="operator token">=</SPAN> L<SPAN class="punctuation token">.</SPAN>esri<SPAN class="punctuation token">.</SPAN><SPAN class="token function">featureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fgis.d3smartcity.ae%2Farcgis%2Frest%2Fservices%2FOperation_layers%2Fd3_Masterplan%2FMapServer%3Ff%3Djsapi" target="_blank">http://gis.d3smartcity.ae/arcgis/rest/services/Operation_layers/d3_Masterplan/MapServer?f=jsapi</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN> style<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">{</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"#70ca49"</SPAN><SPAN class="punctuation token">,</SPAN> weight<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">addTo</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
it should be (no ?f=jsapi):
var parks = L.esri.featureLayer({ url: "http://gis.d3smartcity.ae/arcgis/rest/services/Operation_layers/d3_Masterplan/MapServer", style: function () { return { color: "#70ca49", weight: 2 }; } }).addTo(map);<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
thanks, but I still having this type of error :
Ps : I'm using the npm package "esri-leaflet"
This is a bit out of my comfort zone, as I don't work with Meteor or NPM leaflet package.
I am going to tag the Leaflet group maybe someone there can help.
https://community.esri.com/groups/esri-leaflet?sr=search&searchId=c21df669-81e0-469d-a237-097962db585d&searchIndex=0
