Hello!
I need to customize the filter popup screens that open through the "Filter" option of the attribute table widget. For example:
- Change the label "All" and the label "None", where it says "of the following expressions in this parameter are true";
- Remove the "Field" option.
These options are in the "Add an expression set" option.
Thanks for any help, because I could not find where to change this information.
Thank you!
Gilberto.
