Hi i m naive to arcgis appstudio and trying to create multiple polygons through JSON set of vertices, i have my vetices in json format in db like below, but my geometry symbol do not support it.
Kindly guide in right direction.
Or my question could be like.. how to create a polygon through JSON data
import QtQuick 2.7
import QtQuick.Controls 2.1
import QtQuick.Controls.Material 2.1
import QtQuick.XmlListModel 2.0
import ArcGIS.AppFramework 1.0
import Esri.ArcGISRuntime 100.2
Item { //! [GOSymbols MapView]
// Map view UI presentation at top
MapView { id: mapView
anchors.fill: parent
rotationByPinchingEnabled: true
zoomByPinchingEnabled: true
Map { BasemapOceans {} initialViewpoint: viewPoint
GraphicsOverlay { id: graphicsOverlay
// the center of the mapview
ViewpointCenter { id: viewPoint
center: Point { x: 172.49307355493
y: -43.4810759934974
spatialReference: SpatialReference { wkid: 4326
targetScale: 288895.277144
//! [GOSymbol line symbol]
SimpleFillSymbol { id: fillSymbol
style: Enums.SimpleFillSymbolStyleSolid
color: Qt.rgba(1, 1, 0, 0.4)
SimpleLineSymbol { style: Enums.SimpleLineSymbolStyleSolid
color: "blue"
width: 2.0
antiAlias: true
// add all the graphics to the graphics overlay
Component.onCompleted: { // add boat route
graphicsOverlay.graphics.append(createGraphic(createBoundaryRoute(), fillSymbol));
// add the nesting ground
//! [GOSymbol createGraphic]
// create and return a graphic
function createGraphic(geometry, symbol) { var graphic = ArcGISRuntimeEnvironment.createObject("Graphic"); graphic.geometry = geometry;
graphic.symbol = symbol;
return graphic;
//! [GOSymbol createBoatRoute]
// create the boat route
function createBoundaryRoute() { // create polygine using json
return ArcGISRuntimeEnvironment.createObject("Polygon", {"json": boundaryJson}); }
//! [GOSymbol boatRouteJson]
property var boundaryJson : {"paths":[[[172.49307355493, -43.4810759934974], [172.5030454523, -43.4334343434],
[172.481307356908, -43.391075445974],
[172.47307356908, -43.419075445974],[172.49307355493, -43.4810759934974]]],
"spatialReference":{"wkid":4326}} //! [GOSymbol boatRouteJson]
